Lcr not starting after driving then turning off.. (Fault Codes)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Righto Ive recently fitted a New Coolant temp sensor to sort my fueling and temp Gauging readings which it has done...
But like last time when i go and start it for the first time in the morning is totally fine but sometimes can be in limp mode...
But lets say i go to the petrol station and turn it off then just fill up as usal and then try restart it.It struggles on turning over then it does firer up but has high Idle Revs and Splutters and struggles to rev when you get it going..
But once Rolling for a brief moment and come to a complete stop ( Traffic Lights) its tottally Fine doesnt miss a beat untill u turn it off again... But sometimes when you've turn it off it will just firer back up like normal...
Now tonight coming home the car completly cut out on me and wouldn't start love nor money i had EPC Light and Engine management light on too but after 2-3mins of cranking it over it fired up and boosted fine..
Ive done a scan via vagcom and this is whats turned up...Some of them are repeating like the dv one
6 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
Readiness: 0000 0000
Now the Error in mapped cooling system IRRC would of been my CTS as i havent reset the codes since fitting it...
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Found this via Ross tech
16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
Possible Symptoms
Power Loss
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Engine Speed Sensor (G28)
Special Notes
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah I can do James What you thinking?
Which blocks should i do?
Edit: Just been to get the misses and it was complelty fine even after a really good thrash...
I cleared the codes and no of them have come back as of yet
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
just the usual blocks mate, to see if theres owt going on
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Righto
after resetting the codes ive driven around 50miles to see what codes back and these are the ones..
P1297 - 35-00 - -
P0322 - 35-10 - - - Intermittent
any ideas anyone
I have done the n249/n112 bypass if that matters but was a while bakc
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
Crankshaft sensor sounds faulty with it not starting again. and your speedo playing up
ive checked the codes on ross tech and thats what they say.
