lcr front splitter on to a facelift lc suggestions???
cupra_paul
99
betwwen chair and keyboard
just brought a genuine front lcr splitter only to find that its not going straight on out the packaging:cry:
im sure ive seen a few with this mod done but put a serch in here didnt come back with anything:shrug:
anyone got any hints or tips before i start cutting???? pics??? any info would be appricated:clap:
come on i know you wont let me down ;)
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
click my progress thread, few photos and a bit of advice there. Also on seatcupra.net's infobase pabs has done a instruction set.
bruceR
2,558
647
Monifieth, Dundee
This is quite an easy mod to do. I have done this and used PABS guide to keep me right.
After you cut the 2 center lugs down to size (approx 10mm) then offer the splitter up to your front bumper and get it central. Just use a few bits of masking tape to hold it in place and you can then secure it with self tapping screws.
It might be easier to have the front of the car raised up, I did this without jacking up the car so had to use a dumpy screwdriver :cry:
Hope this gives you a bit of a clue, defo well worth doing :D
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
i just rolled mine onto some bricks which gave me the height i needed. its worth filing down all the lugs so that it fits flush as all of them have little raised bits where it would normally plug into the holes on the LCR bumper
R@B
I Like Turbos!!!
Mar 11, 2009
203
Sunny Glasgow
Here is the guide your looking for-
www.seatcupra.net/index.php?option=com_content&task=view&id=529&Itemid=6
I had to jack mine up when fitting it but it was dead easy only took 10 mins. Most time consuming bit was getting those :censored: sideskirt trims back on.[:@]
Little tip for lining it up, put a bit of insulating tape on the centre of the splitter and on the front bumper( if you want to be anal like me you can measure it to be exactly dead centre). This makes it alot easier to line up if fitting it yourself.
Pabs
5,936
Basingstoke
the splitter still looks flippin' fantastic on a facelift LC.... loved it on mine! Next best thing to the LCR bumper itself ;)
