LCR12npt
Anyone got any ideas? My Lcr is creaking when going over bumps, seems to be coming from drivers side. Have checked track ends, ball joint and anti roll bar linkage all seems fine. Could it be the busehes on the wishbone?? anyone ever had a similar problem.
mine was creaking and squeeking like hell from the rear and later the front. I had my 30,000 service done last week and the greased up the bushes and the dreadful creaking is gone.
had rear suspension creak on mine at about 2k miles, well probably from new but that was when the rain really kicked in.
booked it in they lubed up the rear of the car:shrug: when I asked what parts they said "all of it":rolleyes: okey dokey chaps good answer:confused:
drop links or any cv joint would cause a knock, not a creak. most probs anti rollbar bushes. a bit dubs 40 or silicone spray will sort it. you will have to remove brkts if you use grease so you can get inside or you will just seal the sides and wont be able to get any sort of spray lube in. use a silicone based lube or it will just dry out and the noise will come back. dont use duck oil.
