LCR - Coolant Temp Sensor Query
emocionR225
Hello..I have 2 questions as follows:
1) Have any of you changed your CTS to the 'green' version and, if so, why?
2) If you have a misreading CTS will this ALWAYS show up as a fault?
Thank you
Pabs
5,936
Basingstoke
the green version is known to be more reliable, and hence requires changing less often.
From what i know, a misreading CTS will NOT always show up as a fault - its best to get logging with vag-com and find out if there are any spurious readings from it.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
1) Yes, because I had a fault
2) Don't know. Mine threw "System too rich" codes before it threw the "error in mapped coolant sensor" code though.
