LCR Central air vents...
neilmac
Just starting to tweak...
Jul 12, 2006
294
Guys,
wondering if any LCR owners with climate can help me with this one...Ive noticed that on Auto, when warm air is required (i.e. first thing in the morning) its all getting directed upwards to the windscreen vent. If I select central vents only on the climate controls then air does blow out of the central vents. If I take the temp cold (set > LO) on AUTO then cold air does come out of the central vents.
So the question is, on Auto when warm is required to heat the cabin...should warm air be coming out of the front vents...I think yes as Im sure it used to and has just stopped.....
anyone shed any light on it at all please?
Stan 24v
421
Blackpool
I think its working correctly mate. i think it blows on to windscreen and the side vents to clear the windows.
Gezz
113
Manchester
Its working fine, when hot air is coming out its not supposed to blow directly into your face so will come out of floor and windscreen, when you want cold air this is supposed to blow on your face so will automatically come out of the face vents.
its all in the manual.
