lcr brake pads an disks
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Red stuff are a bit sh1t from what i've heard. Ferodo ds2500s are the best imo. I have the grooved version of that CRN disc on my lcr; i've heard drilled disks can crack due to the temperatures generated in the disc, and the holes providing weak spots.
DannyC87
Mar 4, 2008
3,459
bill at badger 5 (ibizacupra on here) does good prices on ds2500s; and also crn on ebay are pretty good.
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
I think if you go for quality discs they should be fine as a lot of sports cars have grooved and drilled - porsche, ferrari, and mine :)
DannyC87
Mar 4, 2008
3,459
iirc crn discs originate from ebc discs which are then machined with grooves, or drilled
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
CRN are EBC plain disks grooved.
Ultimax are a quieter, less grooved version from EBC themselves. These are good disks also.
I do not advise ebc redstuff pads, too high wear on disks, and not that great a stopping power either. DS2500's far better pads, for same kind of money
£173.02 for front ultimax disks
£96 for DS2500 front pads
carriage-£9.50
prices+ vat
tonyjo
I fitted EBC standard disks on my LCR back in August 2008, they have already warped!!!! [:@]. (very noticeable judder above 60). Only covered 2000 miles, and believe me, the car has NOT been driven hard. (usually have the kids in the back!)
They were bought from ebcbrakesdirect.com, a long with Red Stuff pads. The pads themselves are not great. Although they work much better that stock pads, they are very noisy and only seem to work well when warmed up.
Overall, very very disappointed with EBC stuff, I would never use them again.
The problem I found is, there is much choice out there when it comes to replacing LCR front brake disks, would you agree?
DannyC87
Mar 4, 2008
3,459
I would imagine the pads are to blame for the warped discs; my ebc discs have been fine with ds2500 pads.
J_Cupra210
LCR 210
Sep 27, 2006
49
Blackcountry Boy!
running the same setup here with motul 640 fluid and having no issues.
great setup once everything is bedded in correctly!!
setup was suggested and provide by badger5 for a realy reasonable price.
DannyC87
Mar 4, 2008
3,459
same motul fluid here too :)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I suggest before scrapping these try a proper bedding in process again to see if the problem you have is just pad pick up. As you describe I would doubt if it is warped discs.
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Hope this helps, alot of reading but very informative
