Hi Guys
Followed the guide to change the pads on my LCR yesterday and it worked a treat, well nearly anyway.
I started with the passenger side and it took 20 mins until the new pads were in and all back on the ground, next the drivers side, out came the pins and the pad on the outside, but the inside pad was stick fast, after 30 mins of pushing and pulling it would not come out so I pushed it back further into the calliper so i could push the pistons back in, this went fine, so now the pad is ratting around inside the calliper, but everytime I pull it to get out of the calliper it just gets stuck solid, no amount of wiggling or pulling will remove the pad.
So back went in all the old pads, and a total waste of 3 hours! So now i'm back to where I started, typical it was the last pad.
I wondered if there was any advice I could glean from here from anyone who has had this issue, there doesnt seem that much of a lip on the disc, would the calliper need to be removed to get it out?
Any advise appreciated.
Jon
Jon
