CBass
I have just had the 40k service completed for my LCR and the SEAT Dealer told me that my front pads will need replacing in about 4k miles and that the discs will need skimming to remove the lip that has appear around the edge to stop the new pads sitting on top of the lip rather than flush with the discs.
I have heard that the minimum thickness for LCR discs is 26mm and that the discs are only 28mm to start with so shouldn’t be skimmed. Does anyone have and ideas / views on this? The size of the lip is no more than 1mm, it certainly isn’t thicker than a 10p coin, which I seem to remember is another way to judge it…
If I do need new disc too, am right that the front size is 323mm x 28mm and the rear size is 256mm x 22mm? (I think that is right from searching!)
Looking at either getting some grooved ones from Bill at Badger5 or drilled/grooved ones from The TT Shop (http://www.thettshop.com) in Bedford. I have read all the views on drilling discs making them liable to cracking in extreme track conditions, but as I don’t do this, I don’t see it as a problem. Other guys from ‘another forum’ recommend them and not only say they fit LCRs not LCs but actually have them fitted to their LCRs and are using them. Anybody here encountered The TT Shop before?
