Apr 24, 2007
985
W. yorkshire
Right fitted my new gauge over weekend but not sure what levels to expect.
What seems to be happening is its rising to 15psi then quickly dropping to 12 then slowly sinking to 10.
Now is this normal if not amy idea what could be causing this?
Sorry if someone has posted with this but I cant seem to find anything that suggests the same
Mine is pretty much standard, no mapping, or tinkering with boost levels and mine hits pulls to 12psi and falls to about 11psi holding all the way to 6.5k then fallin back of to about 10psi then!
Hope this helps, your seems to be spiking quite high then holding the right boost!
right think i have pretty much got my levels sorted now it was all down to my split r but i appear to be getting less boost in 6th gear than any of the rest is this normal?
