[LCR] Boost issue
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
Hello!
Sorry if this has been covered before but this is a problem that has been troubling me for a few months...
Basically, when driving on light throttle the boost comes in and occasionally drops back (normally when cold-ish) it kinda feels like an auto box changing up early if you see what I mean?
To start with this only happened when cold and in 1st gear but I have noticed a couple of times today it happens in 2nd and once warm too...
Like I say it is only when on light throttle but it's a significant drop off and I'm beginning to wonder what the cause is and what can be done to fix it?
TIA
Phil
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Lots of "surging boost" threads over the years, some people put it down as a "characteristic"
bcstudent
Boost FTW
Apr 17, 2005
184
Norwich, UK
My LC was really bad for that before I started modifying it. I think the 007P and Forge TIP made the most difference towards fixing it.
Stan, if we do manage to meet up over Christmas I think you'll like the remapped LC feeling. My mate drives a standard Octavia vRS and he was pretty impressed.
Timmyboy
Former Cupra Owner
Aug 27, 2005
108
Bristol
Mine was suffering from that until my re-map last Thurs, but unfortunately I had the map and a Forge 007P fitted at the same time so I'll never know which cured it :) (and a panel filter but, meh)
Mar 26, 2007
2,020
S.Wales
mine does this too, i think my coil packs may be getting towards the end of their life so i guess this could have something to do with it?
Stan 24v
421
Blackpool
A dodgy coil pack would give you a miss on one or more cylinders mate, the symptoms are quite different, I know as Ive changed 2 on V6 engines!! :blink::cry:
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
just in case this helps.
my lc used to regularly surge at idle and when driving with light throttle. it would surge 300-400 revs. once the engine was warm it calmed down.
i tried everything. it was almost dangerous to drive.
turns out that moisture was building up in the maf connection causing arching.
hence the fluctuating maf readings causing surging revs.
di-electric grease from ebay blocks out the moisture. takes about a week for the surging to stop. well it did for me.
the tdi lot use it and theres a few threads on here.. i think they nicked the idea from the vw lot:D
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Mine suffers from the same problem from time to time.
I clean the Throttle Body with WD40, re-aligned it and reset the ECU and its perfect again. I seem to have to do that twice a year and it lasts 6 months.
I think is is a characteristic of the adaptave ECU and it just needs to forget what its learned every so often.
Mar 26, 2007
2,020
S.Wales
I'm aware of the symptoms of a failed coil pack, I was implying that perhaps a coil pack on its way out might f**k up the timing of the sparks firing as opposed to them not firing at all.
