May 13, 2007
1,017
Denmark
Hi there!
My local tuner is doing a Brembo GT(not org. set brembo's) upgrade on my car, and it's doing my head in!
The calibers are so much wider, and even though my alloys are 18" 8,5" et 34 Projekt Zwo, they are still hitting the calibers!
So we are about to try out some 5mm spacers, which will be fitted in each corner!
But. how will this affect the fenders etc? will hit the fenders on full turn etc??:shrug:
surely that's down to the wheel inner design itself then as the diameter is large enough probably too large and wide with fat spokes for extra strength
what are the brembo's off?
standard wheels are 7.5x18 et38 iirc
i've run 15mm front and rear spacers with standard lcr wheels with no problems at all if that helps..
