LCR 225 vag scan 305 help with EML codes needed
Richard123
Rickys LCR 225
Feb 4, 2013
169
Ayrshire,Scotland
Hi guys looking for some help with EML codes. I am using a a Vag scan 305 .
Engine codes:
First code : 18010 the book i have says Power Supply B plus terminal 30 low voltage ?
second code : 17705 the book doesnt have number closest is 17733 knock control limit or 17656 fuel level low?
third code :16486 book says MAF mass air flow low input?
ABS Codes: 01314 I cant find any referance to this number in my book either ?
any help on this would be great guys! thanks.!
Richard123
Rickys LCR 225
Feb 4, 2013
169
Ayrshire,Scotland
Thanks for the reply , but when I go to this site the bit for my car is greyed out . And s3 and tt both dont list 1.8t ? Am I doin something wrong here? Cheers
Sent from my GT-I9505 using Tapatalk
mr.brown
53
I had the second and third codes on my Cupra and it was due to the PCV hoses being shot.
Richard123
Rickys LCR 225
Feb 4, 2013
169
Ayrshire,Scotland
Hey Azza,thanks for reply ,Yes I have cleared all before so this is whats came back both times.
I had the car round at my mates garage to have alarm bleep and windows close by remote last night :whistle: he also did scan with vcds:
Pressure drop between turbo and throttle valve,I will check DV over the weekend.
Mass air flow low input think maf sensor might be on way out ,as it says intermittent and I have removed cleaned with carb cleaner and refitted few months ago.
I will try cleaning it again with throttle body reset if that doesnt work its a new one next month.
Power suply B plus terminal low voltage ?
ABS code says Engine control module No communication?
any ideas on last two guys? cheers again. .
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Power supply B code = battery disconnected
That check dv code could also be an air leak. If your using a forge piston valve thats older than 8 months its worth servicing it.
Richard123
Rickys LCR 225
Feb 4, 2013
169
Ayrshire,Scotland
Hey Mr Brown,thanks for reply.
Ok I will look into this,I was planning on doing pcv delete anyway as soon as i can afford a catch can .
Ive just had new clutch kit and dmf £400 , fitting £150 and two eagle F1s £190 total inc fitting £740.
Bank balance pretty low now lol. Always something to be done!. thanks again guys!
