Hi there,
I'm after some advice / opinions on the fact that my car has just failed it's MOT on emissions.
Here's the car spec & modifications:-
Leon Cupra R 225 ’05 102K mileage now on the clock, owned from 6.5K
Full Seat service history / VAG specialist
Remapped by Bill (Badger 5) 279BHP 275lb/ft March 2013
Bill’s 3 inch TIP & Jetex cone filter fitted by Bill March 2013
Forge DV with service kit done by Bill March 2013
Cobra turbo back exhaust with 3 inch downpipe & 200 cell sports cat fitted before the remap by Cobra March 2013
MOT results:-
Oil temp 101 degrees
Fast idle test min limit Max limit Actual value Pass/fail
RPM 1/min 2450 2850 ----- Not checked
CO %vol ----- 0.300 1.457 Fail
HC ppm vol ----- 200 98 Pass
Lambda 0.970 1.030 0.964 Fail
2nd Fast idle min limit Max limit Actual value Pass/fail
CO %vol ----- 0.300 1.498 Fail
HC ppm vol ----- 200 99 Pass
Lambda 0.970 1.030 0.962 Fail
Natural idle min limit Max limit Actual value Pass/fail
RPM 1/min 650 870 ----- Not checked
CO %vol ----- 0.500 0.718 Fail
Would these figures suggest that the sports cat is not working, or has there been a sensor failure?
I have two weeks to fix this for the MOT retest, but I also need some feedback if it’s purely down to the cat that’s not doing it’s job. I have one years warranty left on the sports cat but I need some assistance on making sure I have a case that it’s the cat & not something else.
Many thanks.
Alan
MOT results:-
Many thanks.
Alan
