Lateral Acceleration Sensor (G200):
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
01423 - Lateral Acceleration Sensor (G200): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Basic Setting not performed
Possible Solutions
Perform Basic Setting---------- What is this?
Hi, my esp light came on and this is what vag com says, code 01423 came up , the question i have is how do you do this "Perform Lateral Acceleration Sensor (G200) Basic Setting" i have phoned the stealers and replacement G200 is £700:cry: has anyone else had this? any help gratefully accepted:D
01423 - Lateral Acceleration Sensor (G200): Electric Circuit Failure
Possible Symptoms
Possible Causes
Wiring/Connections from/to Lateral Acceleration Sensor (G200) faulty
Supply Voltage insufficient
Possible Solutions
Check Wiring/Connections from/to Lateral Acceleration Sensor (G200)
Check Supply Voltage
Check Lateral Acceleration Sensor (G200) faulty
Retrieved from "http://wiki.ross-tech.com/index.php/01423"
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
*leave the ignition on
*clear the fault code in the engine module
*then go to measuring block, select block 060
* then press press switch button athe bottom of the screen
this will lock all the field and do the adaptive alignment. Give it a minute, then press done
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Cheers i will try that, when i tried to clear the fault yesterday it just flashed but remained on the screen, also when you say engine module is it engine - in common, or engine in drivetrain, sorry but i am new to this.
sicupra
im havin same prob. in told a new 1 is £120 from dealer.
its located on steerin column on left hand side bout half way down.
if u know any1 with elsawin just put g200 in the search bar on maintenence and ul get diagrams and full instructions.
Stan 24v
421
Blackpool
Guys why does a TB align clear the lateral acceleration issue? One is steering, the other is air intake??? Is there a bug in the software or something?
GTI-CRAIG
digging around found this post any one have a vag com in west yorkshire and a spare 10 mins ?
for beer tokens ;->
