lambda sensor spacer
jamie1
352
south east
Am having trouble trying to find a lambda sensor spacer, am fitting a decat soon so will need a spacer i believe, or, can i just leave the sensor plugged in but no wound into the exhaust? Have read through a few threads but cant seem to locate one? Have also tried ebay etc but am still struggling trying to find one! I may be being stupid and blind but can someone point me in the right direction please.
Thank you :)
Mar 3, 2009
823
Hinckley
It needs to be a right angle one, straight one won't fit. Not in mine atleast :( search for Wayne angle block, expensive but does the job
jamie1
352
south east
can the sensor just be left disconnected from the exhaust though or will it need to measure some sort of flow?
Jul 29, 2006
723
cumbria
www.facebook.com
Don't bother mate just fitted one,bringing up new fault codes and car runs crap, getting it removed later today.
2 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-00 - -
Readiness: 0000 1101
jamie1
352
south east
anyone? can the sensor be left un-wound from the exhaust and is the wayne angle block the only spacer avaliable?
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
2 Faults Found:
P0133 - 35-00 - -
This is strange as i had these faults before i fitted my spacer, now my spacer is fitted i have no fault codes. Did you reset the ecu after the spacer was fitted, if not thats why you still got these fault codes.
sambryant
Mar 26, 2009
4,848
Bristol
No make sure the sensor is plugged in. The spacer works perfectly i will post a link up for you in a few mins where you can buy one. You can only get them from the usa tho. If you go on and fit the decat you will get a fault code and the engine light on but it wont effect you car, i ran my decat for months without the spacer, all was ok. The light on the dash did my head in so thats why i fitted a spacer. All good now
jamie1
352
south east
ok thanks. so even if i leave the sensor plugged in but not in the exhaust it wont work? the link would be handy though, cheers.
Jul 29, 2006
723
cumbria
www.facebook.com
Hi mate,yea, car had a battery reset and everything cleared and reset with vag-com, just wasnt happy with the idling and car felt bit sluggish,took it off and all is fine,xept light back on[:@] but will have to live with that till decide to stage 2 it.
