Lambda Sensor "O2"
kenty
Hi all,
Had the engine check light come on whilst driving today so on arrival home plugged in the scanner and revealed
PO136 - O2 sensor circuit malfunction, Bank 1 Sensor 2
Having checked the second lambda sensor i found a dry connection and 2 wires broken.
So my question is anyone know the best place to source a new one??
Cheers Andy
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
if its just the wiring, cut the ends and join them (bypass the connector), I had a couple of spades break off in the connecting housing and instead of forking out the 70 quid or whatever for a new one. works fine now.
Avant4me
359
Bristol
Hi all,
Cheers Andy
Personally, i would only use genuine parts when it comes to electrical components, had bad experiences with a MAF from Euros.
If its the front, i have one i used for testing. Genuine VW part
Matt
kenty
Nice thought except its the other end :cry: where the wires come directly out the probe i think the heat has cracked the outer case and dried out the wires inside.
kenty
I'll do the usual ring round tomorrow and see if i can get some christmas discount :p
