lambda probe need replacing?
gazjones
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 06A 906 032 QN
Component: 1.8I R4/5VT 0010
Coding: 11500
Shop #: WSC 00222
VSSZZZ6LZ5R073987 SEZ7Z0D2639286
1 Fault Found:
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-00 - -
Readiness: 0010 1000
had this code twice now think first was intermittant, 2 days ago car was juddering on cceleration could this be related?
gazjones
anyone? im off on holiday today so wontbe driving it any more but if it needs sorting will have to do it right away when i get back
Uwe@Ross-Tech
392
www.Ross-Tech.com
IMO, chances are good that the sensor is shot, but the repair manuals generally suggest several tests before replacing the sensor. One suggestion can be summed up "Drive it like you stole it for a bit to clear the sensor of any residue".
-Uwe-
gazjones
its running fine but some times judders from cold its still in warrenty so should be replaced free is this the first sensor or the second along the exhaust?
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
yup, sounds trashed mate, just changed that one on mine the other night. It was running terrible, would not idle propperly, popping and banging, juddering at 5k plus.
gazjones
its not that bad running ok but will see if a warrenty claim will sort it if not it will have to wait
gazjones
is it possible to swap them over as my second one is redundant on revo stage two i belive!
gazjones
no nothing is ever simple lookes like both probs are different on mine so trip to dealers and ive not cleard the code so they will find it, made sure of that will see when i get back to england
gazjones
being replaced wonder if i gradually lost performane i hope so as it feels quick still i want more free power!!!!!
