hi ryan, get someone with vag com to check it, its gonna bring a code up telling u which sensor is faulty if its a lambda, and no, i'd say for sure the lambda probes for a diesel will be different to a petrol so non compatible. i have a vag com scanner which reads and clears fault codes, cheap enuff off ebay now, and told me exactly the fault and cleared it after i'd changed the part. job done
