Hi guys, I'm in need of some help.
The last few weeks I've been having several codes, and I am not quite sure what is going on.
16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
Possible Causes
* Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
Possible Solutions
* Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Mass Air Flow (MAF) Sensor faulty
* Oxygen Sensor Control faulty
o Oxygen Sensor(s) faulty
* Fuel Injector(s) faulty
Possible Solutions
* Check Mass Air Flow (MAF) Sensor
* Check Oxygen Sensor Control
o Check Oxygen Sensor(s)
* Check Fuel Injector(s)
I deleted the codes several times now, however the light keeps coming back on. Not immediately but soon enough.
The car is running perfect at idle and drives well also. No backfiring or anything.
I am getting limp mode sometimes though, where I cannot get above .03bar of boost, no matter how hard I boot it. Then in the same run, I all of a sudden hit proper boost again.
I have tried disconnecting MAF but not changed anything. The one time I will hit 0.6bar and then next only 0.3
Can a lambda sensor really cause limp mode?
Worth taking it out and giving it a good clean?
cheers for the help
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
cheers for the help
