Lambda failing?
Mark@VAGWORX
SEat Regular
May 15, 2003
401
Nr Colchester, Essex
Will you always get a fault code if one of the Lambda probes is failing?
Reason i ask....
Logged my MAF readings the other day. Was only seeing 130g/s, but the car still pulls hard and goes really well.
I've since tried 2 new MAFs. I've logged them and seen higher values, 145-150g/s....but.......the car runs like a bag of spanners. Massive amounts of lag, and then goes like the clappers when i finally get boost. But, as the car gets hotter, it runs worse and worse to the point that it even stalls.
Now, is this due to a dodgy Lambda, rather than a dodgy MAF? Just thought that is the new MAF is flowing higher values, then a dodgy Lambda is not controlling the fuel/air mix very well.
Any suggestions?
Mark@VAGWORX
SEat Regular
May 15, 2003
401
I disconnected the battery, for 10-15 mins and reset the ecu. I thought it auto aligns the TB during this process?
I've had no faults codes, and i've still got no fault codes.....
