Lamba's??
Craig1985
Right guys needs anit of info what lamba's are people using on the ihi conversion's?
As i need a new one so didn't know if people run uprated ones??
Jun 1, 2007
760
on my leom 180 ihi im using a a 225 BAM engine code lambda but the plug is bigger than the ibiza one m8
ps u done any good phone jacking a late :fool:
Nov 2, 2004
9,335
South Wales
As far as i know you have to have the standard ibiza one, which means its no good for a a/f gauge. If you want a a/f gauge you have to install another 02 sensor.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
if you mean for ecu control, then your stuck with narrowband on ibiza ecu.
external additional (or one with narrow band output) controller/gauge is what wil get you wideband.
Well advised to do, as well as egt especially on IHI, depending on where you got it mapped.... ignorence is not neccessarily bliss if it runs lean. (engine damage)
VEMs looks like a nice one. I run zeitronix
