Ko4 Mk3 Ibiza Downpipe
TurboCupra
190
Looking for someone who can provide the following really:
A decent quality downpipe for a mk3 Ibiza running a std. TT mainfold and Ko4-023. :confused:
Also anyone who can tell me if the TT boost pipe (one that goes round the drivers side) will fit under the bonnet!? :shrug:
Henry
Feb 1, 2007
1,293
gloucester
im not sure if hooch bought his of someone on here , or had it made up , as he had a k04 that he sold to me , the downpipe was a nice bit of kit , where are u located
t18con.
hooch bought my downpipe originally, someone on vortex makes a k04 to k03 downpipe convertor, or qpeng do one without cat for a mk2/3 golf which might fit, when fitting the k04 , i fitted mine to our original over the cam cover pipe, no problems.
mk1golf_jack
Golf nut
Mar 13, 2007
80
Herts
I have the qpeng 2.5inch downpipe for mk2 golf fitted on my k04 ibiza it requires modifying to fit (cut a section out and re angle it) but was essentially a bargain as long as you can tig weld or know someone that can. If i did the conversion again tho i would buy the flange and assorted straights and elbows and do it myself! Hope this helps
TurboCupra
190
Reading in Berkshire mate,
Qpeng item sounds promising, welding and re-anleing shouldnt be to much of a problem, is it one cut and re-weld, or more of a challenge than that!?
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
if you get the right qpeng one it fits stright on with a tweek! trust me i know of 3 ibizas with them on
i had your one t18con but i didnt like it plus it was full of crack. had a stainless one made
TurboCupra
190
Full of crack!?
Looks like qpeng is the way then...
Cheers folks
Deleted member 9043
does the qpeng mk2 golf pipe also fit my lhd beeza?
mk1golf_jack
Golf nut
Mar 13, 2007
80
Herts
jack you are the only person i know off that had to weld it
That just about sums up how good luck fails me everytime! when i had it on before welding it was pushing the gear cables against the passenger side of the exhaust tunnel. I could have ran it like that but it would knock like mad. Everytime i go to work on a car its 10 times more of a mission when i own it lol. Whichever way you look at it, tis a good bit of kit and good customer service from qpeng!
