str8ballin
211
Hi all,
I have put the K04-23 turbo, mani, injectors etc on my AYP block.
This turbo has a EGT sensor on it but my AYP ECU doesnt need that reading, so I was wondering is it possible to connect it to a EGT gauge?
It has electrical connections so not sure if I can use the existing cable or if I have to get a new one.
Also does the 225 have a wideband 02 sensor in the D/P or is it the same as the mk3 Ibiza (AYP) etc..
Sorry if these are silly questions!
Many thanks
EGT sensors have temperature compensated cables generally.
You can use the port for your sensor and guage for the thermocouple they would supply with it (usually 1/8" npt), type K thermocouple.
