Hi, my question is not really related to tunning area, but I would like to know how all the inputs and outputs of KO3 turbocharger are connected - I don't mean compressor and turbine inlet/outlet but shaft oiling connection, wastegate connection, blow off connection...
Below is some picture of KO3 turbocharger, where you can see more than 2 openings. I will say than plug 1 and 2 are used for shaft oiling, but don't have clue what are other two openings for.
Also on any gasoline engine turbocharger picture there is any blow off valve. Does this mean that blow off valve is a separate part? Is blow off valve in any way conntroled by the ECU or is just a mechanical valve?
Then as read wastegate valve is air pressure controled via N75 solenoid valve that is electricaly controled by ECU that among other inputs also uses MAP sensor readings to determine the necessary boost. But here on this picture wastegate is connected directly to compressor high pressure outlet. Is this just the case with new parts and wastegate is really connected to the N75 or can some turbos have mechanicaly conttroled wastegate?
aslo some simple turbocharger schematics
![2l6-ko3.jpg](http://www4.slikomat.com/09/0827/2l6-ko3.jpg)
![boost_control.jpg](http://s2central.net/images/boost_control.jpg)
