Knocking sound when turning engine off
Hampa1
102
55
A few days ago I noticed a distinct knocking sound while turning the engine off (vz310).
The sound seems to come from just below the armrest in the center console but that’s not where the sound comes from, probably below, maybe the gearbox?
It’s not there everytime, but particularly noticeable if I turn the engine off while gearbox is in reverse.
I haven’t noticed any gearbox issues or strange sounds while driving, still smooth as always. I will have the garage take a look at it in a couple of weeks while booked to check an issue with the climate control.
Anyone else noticed this?
Korefan
36
Latvia
Sometimes the same knocking you can hear when Press P button on the center console.
I think it is ok.
pkaps
vz310
May 10, 2022
274
132
Should be the gearbox going to P, can't think of anything else, I wouldn't worry unless it gets worse by time.
Hampa1
102
55
Hopefully that’s it, just strange that it suddenly starts to make noise after close to 1 year. Will mention it to the garage though.
Hampa1
102
55
The knocking sound has been confirmed by the garage, I will get the car back tomorrow after 4-5 days looking for the sound. They could reproduce it with my car and with another car as well. The factory confirmed it’s how it’s designed and that it’s not a fault. The explanation is that it’s something with the handbrake wires when the engine is turned off (sometimes). I will get the details tomorrow but it’s reproduced and registered In case it becomes an issue later on.
Kingskullz
66
18
Do you turn your car off while its in reverse? Or do you press the P button before turning it off?
Hampa1
102
55
I usually just turn the engine off, sometimes in D, sometimes in R. I haven’t noticed any difference. The parking brake is set to be activated both ways I believe. Picked up the car today and I couldn’t reproduce it, but it only happens from time to time and there’s no logical pattern. It’s a rather loud ”knock” from the center console/gear selector area. I’m still waiting for the written explanation.
Reactions: Vissa
Kingskullz
66
18
Well, I have no idea if it makes any difference but I always put the car in P before turning the engine off. Also, I think the parking brake does not engage if I don't pull it as one time I forgot to engage it and the car leaned back a bit once I depressed the brake. I'd recommend asking the dealer or a mechanic for a bit more accurate advice on turning off the engine in D/R
Hampa1
102
55
Hello, I have the same sound while turning the engine OFF.
[SIZE=3]Hampa1[/SIZE], do you get any explanation from Cupra?
They explained it as normal and by design, no details.
Never heard it in my previous Golf R Mk7 but it’s not the same gearbox as the VZ310.
I don’t hear it anymore since I put it in P before turning the engine off.
Oct 24, 2024
Hi , I also yave this noise, knock noise that come when i push the start/ stop button.
Usually i push the parking button then the hand brake ( parking ) then start and stop .
Its new noies the car is new its 10 months on the road , I haven’t yet go to the garage.
