Knocking noise from rear spacers
Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
Has anybody had a problem with 20mm hubcentric rear spacers? I fitted mine yesterday and immediately i knew there was a problem when they made a knocking noise. It seems to do it mostly when setting off upt to 20mph and when braking at low speeds, Ive got 17's and coilovers but they arent really low, ive also taken the wheel off to have a look and i cant see and catching anywhere. Im going to take them off tomorrow incase its doing some damage :cry:
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Have you checked all bolts?
Mine might be different to yours, my spacers fit to hub then wheel to spacer, no long bolts, need to check mine though anyway...
Tall-Paul
Nov 12, 2006
671
I found out before it was my wheel bolts were too long and were going throught the spacer by 2mm and causing the disc to move and catch on the pad. 1 of the bolts had actually loosened the screw that holds the disc on, by the time i found out the pads were nearly on fire!!
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
you shouldnt be having any probs i didnt! just take the rear wheelsoff makesure the spacer in knockedonto the hub FULLY and the bolts arent too long and try again :)
rashcupra
Oct 15, 2006
6,517
crawley
id stick to the longer wheel bolt idea rather than the bolt the wheel to the spacer then the spacer to the hub as ive heard of problems with these
Tall-Paul
Nov 12, 2006
671
My bolts are only too long as they were supplied with my alloys, so im after some original ones now.......any ideas wheres best? I didnt keep the olds ones as i sold them with my old sport alloys :( When i get the right bolts i shouldn't have any problems at all and i cant wait to get them back on!!!
