Knock when turning - found rear spring unseated
Kambo
197
Hants
Turn left - knock, turn right - fine
Just the one knock (or heavy clunk if you want) from the rear passenger side whether you are pulling away or just turning left at any speed
Searches came up with all the usual stuff like loose wheel nuts, bushes worn, ARB (if fitted) loose or broken spring
Jacked up rear passenger wheel and had a shake - nothing, took off the wheel and shook all nearby components and nothing, stuck my head in and had a nosy, found this
Rear spring was unseated at the base?
The spring housing base was still solid and not torn away but the bottom ring of the coil was sitting a shade over and unseated, I've not jacked up the rear of the car in the three years I've owned it (never had the need) its a daily driver so never seen a track with me, everything on it is stock no mods, front has only ever seen a jack on one side at a time for tyre changes, haven't hit a crest lately whilst out commuting either before you ask :rolleyes:
Any idea why this would be? Just wondering if its a Leon/mk4 Golf thing or just a one off thing?
I took off the lower shock mount bolt and dropped the rear frame on that side and with some effort prised it further down and managed with a pry bar to "pop" the spring back in its place, shock back on and frame back up and its seating fine
Took off other side rear wheel and obviously the spring was sitting fine
Will take it out tomorrow for a test but any ideas on why this happened?
I like problems that are known and expected or simple to explain, I don't like the ones that are none of that! :help:
mucka88
47
Hiya ive got a knocking sound from rear maybe simliar problem.
Thinking about it i havnt put the bolts in the bottom of the rear spring carrier as i have got coilover on.
Fit them on tomoro :)
mucka88
47
Also mine seems to knock just on acceleration so was thinking on cv joint.
But you reminded me of the rear bolts...thankyou haha
