Key reprogram??
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Hi All I bought my leon 20V T today!!:funk: :funk: :funk: Only thing is i only have one key, It there any way i can reprogram a new key myself? Hope someone can help?? Thanks
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
thanks
thanks alot for the help but im still not sure what to do? someone posted about holding down the button with a key on it and then pressing the blank button but mine are an open padlock and a closed one?? I have now seen 3 or 4 different methods and dont know which is right?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sorry yours is a leon
theres a post somewhere about it - im sure
gimme 5 ill hunt it down
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
scrap that - i sent it by email
firstly try the door lock to make sure the central locking works anyway - always worth a check :)
this will sound daft but bear with me :) you will need 2 keys - not neccesarily remotes just a second one that you can use in the ignition
right ya ready (read through it first to get the run down)
1 - get both keys - the one with the remote (A) and the normal key (B)
2 - note this must be done within 30 seconds as the synchro process cuts off after that (all will be revealed)
3 - make sure the car is unlocked and the window open before you start
4 - use key (B) to switch on the ignition (lights on dash NOT startup)
5 - use key (A) to lock the drivers door manually (ie key in the door lock) or NS if you have the 2002 on model with only one door lock
6 - now UNLOCK then LOCK the drivers door WHILST HOLDING the unlock button on the remote
7 - once done take key (B) out of the ignition - sorted
Daz
PS - even though its lighting up its best to change or at least test the battery(ies) for a minimum of 3v any less then change them - see http://www.seatcupra.net/knowledge_base/fitting_guides/key_battery_change_guide..html for help and a guide how
any trouble let me know - ill help if i can - and just be glad pedro didnt add spin round 3 times and stand on one knee to the procedure - its daft enough as it is - lol
note the above only solves the remote locking part - the passive built in immobiliser will need to be coded in by a dealer or vag com user
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Ok think i understand ?? But just found out the only key i got dont work on remote something inside has come off. Maybe i need to pay out on a new key now:headhurt:cry: I was hoping i could do it on the cheap but never mind more overtime at work i guess. Thanks for your time and help. Im sure i will have lots more questions as im crap with cars.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
you can get the remote piece seperate from the key so all you need is a spare solid key
try local keycutters/locksmiths as some have been known to be able to clone the original chip into a new spare
will leave you only needing a remote piece then
