Kei's are on!!! and handbrake is broken
sirjimalot
JIM-MAN
Aug 10, 2005
534
County Durham
right ok there on but does anyone else think it looks super high??? its on 35mm springs so what else do u think will make it look lower???
oh when i had put them on i tried moving the car but it felt like the handbrake was on so i thought it might be the 50mm bolts i put in (and craig) so i took them out and put shorter ones in but now my handbrake is naff so could i have done any damage???
cheers
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Definatly needs dropping further, a 35mm drop on 1.4 springs takes it to the standard Cupra height. I'd be looking at going for either a full kit, or some 40mm drop springs from a Cupra!
As for checking the hand brake, jack the car up, back wheel off, center hub cap off, remove 28mm (i think) nut, and then slide the drum off. You'll see the handbrake cable which is wrapped round a spring. The drum set up is dead easy to strip and repair.
sirjimalot
JIM-MAN
Aug 10, 2005
534
County Durham
right ok cheers craig... my car is now 1.5 inches higher than it was with the standard wheels.. so at least now my exhaust doesnt hit curbs.. :-D
