k04 mainfold ?
jamesgtturbo
55
derbyshire
Hi sorry if this has been asked a thousand times before , ive had a search around but cant seem to find the answer ! does a ko4 turbo fit directly onto the stock exhaust manifold ?
thnaks james
by the ways the cars a mk3 ibza cupra
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
as said nope.
if you want std fitment but k04+ power, go hybrid..
by far the best bolt on upgrade for high 200bhp figures
cuprachrissy
yes the manifold will fit onto your block but not onto the turbo.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
A k04 turbo will not fit your manifold. If you want to fit a k04 you need to get a k04 manifold which will fot your block. You also need a few other things to make it fit and work and its not cheap so a k03 hybrid is a better option.
fudd
if you do want a k04 and find a suitable setup make sure you get both oil lines and the water pipe setup , if your missing these they are expensive at the dealer so factor that in when pricing up different setups thats for the k04-023 as i have done this conversion
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
A k04 023 is the turbo which people mostly refer to as a k04 and comes on 1.8t engine that have 210/225bhp so some audi tt, audi s3 and leon cupra r basically. They are good for upto 280bhp.
A k04 001 is basically a k03s, which is a later develped k03 turbo which has slightly larger inlet. They are standard borg warner turbos and are not as big as k04 023 turbos and cannot produce as much power with a max of about 240bhp for both k04-001 and k03s.
jamesgtturbo
55
derbyshire
Just too add could anyone advise me on the best way to check a k04 when its fitted to the car . i.e numbers characteristics of the turbo . basically just to check it is actually a k04
thanks james
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
thanks james
i take it your looking at buy a car with one fitted? be careful, ive seen a few cars for sale trying to pass there ko4 001 as a 023 car quoting the turbo was from a lcr when actually its a 001 turbo.
the 023 turbo exhaust housing exits very differently to the ko4 001, this exits the same as the ko3/ko3s you will be able to see this when looking down the back of the engine, also if its a ko4 023 car it would need 225 injectors 3inch maff tube lcr tip custom dp, these are the bits you would be able to see
jamesgtturbo
55
derbyshire
Its got all the above , unsure of the injectors though ! thanks for the advice bud !
