K03s fitting issues
Ok so I am finally getting somewhere with the fitting! Just got the TIP to go on as I was just trying to get it on without cutting any off of it.
But my problem is that when I took the K03 off, there were 2 vacuum pipes going to the actuator. Now on the K03s there is only one connection. What do I do with the other pipe? Bypass it?
After I sort out this it will be downhill! As long as everything works after... :rolleyes:
Also what is it that connects to the bottom of the TIP? Is it the hard pipe that has a small 5mm/6mm alley key holding it to the rocker cover?
