k03s fitting help
karl.w
methanol junkie
Oct 26, 2005
606
I have got a k03s turbo which i am going to fit soon.
All the oil and coolant feeds are still on the turbo i want to no if i can keep them on the turbo and dissconnect them from the block insted to try and make fitting a bit easier.
has anybody tried this or is it a wasted of time
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
Disconnect all the pipes from the turbo apart from the water one that connects into the driverside of the block! thats the easiest way
hooch
bbsboy
89
just remove everythiong off the turbo, its a good full days work with good tools
ibiza-cupra
494
castleford
did mine at work at same time as fitting decat/exhaust samco induction.i removed pipes as i saw fit to do so still a twat of a job took me four hours using power tools etc
karl.w
methanol junkie
Oct 26, 2005
606
Im planning to decat it at the same time as fitting the turbo.
Problem is that i havent herd 1 person that hasn't said that it was a:censored: of a job to fit a k03s.
karl.w
methanol junkie
Oct 26, 2005
606
whats the best way to get all the kit to fit it. ie gasgets, washer,s bolts and stuff.
Should i go to seat or vw of buy the A&M fitting kit.
h17och
Sep 1, 2005
3,504
Dunstabubble
just go to a seat dealer, there is a list of all the part numbers on here! its not a hard job just a time consuming job
Olly20VT
1,234
Stroud Glos ,England
This is what i used but some of the bolts you prob dont need but i got them just incase.
i have a quetion aswell wich i should have asked before i did mine, what torque setting are the water and oil lines ment to be done up to?
Thanks olly
