Just had the Custom Code stage 2 remap :)
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Sweet ninja!!!! All looking well good! Saw your car at FCS and i saw you on the way out to, i was the guy sitting in the passenger seat of toms silver 106 gti.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
they would have had to disconnect the downpipe to connect the new turbo up, and studs tend to snap and cause trouble
didnt know they fitted a wideband lambda sensor tho? would that need a modified hole?
sounds nice though Dan, been waiting for that since u got the car im sure!
Yea, a tuner should use a wideband sensor to ensure the AFR is spot on when making adjustments to your car. As standard the Ibiza comes with narrowband ones which are as much use as a chocolate tea pot :) Last thing you want is your car going lean under a full boost situation!
JBS Sales
Martyn said:
Because a k03s isnt capable of doing that, well not past 4.5-5k anyway. You could always prove Phil and myself wrong with some 115 & 118 logs from Vag-com :)
I guess you had your car tuned with wideband ? or have any idea of the lambda values used ?
The boost response on this car was great,had all the correct bits in place .
Good boost form the top end and will hold 17.4 psi @ 6k. FACT !!!
Lambda set to 0.82 and MAX EGT's well within spec :)
All in all a GREAT code for the K03s powered,highly modde Ibiza.
Have fun Dan :)
Stuie
93
Swindon
sounds great mate....cant wait to get all my stuff fitted and mapped,almost got the money to get it all done now, and after reading this, i need to get that exta money quick :D
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
PM me if your due down in basingstoke mate, can meet you in tesco car park, would like to see how she runs!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
ian_jobson said:
17.4psi isnt 21psi tho?
I think the 21psi is the usual mid range spool in 5th = high load. Unless he has been exploring 150mph+ of course in which case the revs would be high too. :)
GaryM
Golf GTI 1.8T 180
Feb 11, 2004
378
Nr Manchester
I'd love to see your 115 logs, I thought mine flew after having numerous revisions of CC Phase 2 yet I have never seen above 13-14 psi at 6K.
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
I would happily post logs but never managed to get vag com working.. Think its probably a dodgy cable as i've tried it on 2 laptops!
Will try to get a new cable sorted.. is it ok to just get a cheapy one from ebay ?
