Just had a Ptorque Map and want to log things...
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Hi Peeps,
Got vag.com and wandered what are the best blocks to log to test my new boost.....make sure its making it and what kind of level its boosting at etc?
Any particular blocks that would be interesting to post up?
Rich
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
block 003 to show maf values, 115 to show actual vs requested boost and 118 to show intake temps and wg duty
depending on your laptop u might want to do 1 or 2 blocks at a time to get the best sample rate.
remember 1500-7000rpm
Funkyfin2000
Oct 6, 2005
2,477
excellent thanks guys, will get that done and stuck on the vag.com graph or get the figures up either or....over the next week :)
after the map i suppose i should be talking about 190bhp?
Any idea on torque?
Funkyfin2000
Oct 6, 2005
2,477
having an issue with surging actually...
had a new maf back in November...
just took it for a run (not loggin - been to footy) and when in fourth or fifth and you floor it..... sometimes it will surge, no boost there and then suddenly boost...
it did this before the mapping....so i know its not necessarily that......
Essex_Cupra
466
I can't seem to do 115 & 118 Says my VAG - COM needs to be registered and activated?
I got the lead from ebay so can i do this?
Fault codes are 17536 Fuel Trim Bank 1
17968 & 18010
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
when you installed the usb cable, windows should have created a virtual serial port for it? what port is the usb cable on? You vag only read Ports 1,2,3,4.
Big_daddy
Oct 20, 2006
3,930
Brummy
yeh true say, but some need functions should still work, should pay and get it fully activated
Essex_Cupra
466
Its set to port 3 or com 3 not usb no option for that on the 409.1 software.
How much does it cost to register ?
Is there not another way?
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Costs $99 to register, so about £50 at the moment. And no, there isn't another way. If you want the logging features and the full version of the software, you need to pay for it.
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
there is another way - but its illegal i think, using a program called x-starter and a crack, i've never used it..........
