just fitted dynatwist and..
markupra
Newbie
Sep 4, 2006
54
will have a look now, but as far as I'm aware its all plugged in right.
and why would the traction control light come on??
bigjode
504
Traction light comes on when MAF is dead. could have killed it when fitting the Dynatwist.
The engine light doesn't always come on when MAF is unplugged though :confused:
markupra
Newbie
Sep 4, 2006
54
so it's definitely something up then, not just a consequence of fitting the dynatwist? It seems to drive fine, a bit less torque low down maybe but I assumed that was because of the induction kit.
markupra
Newbie
Sep 4, 2006
54
no I don't :(
by the way, don't know if this is normal, but there is pretty much NO noise from the dynatwist, just hear a slight hiss of the turbo
markupra
Newbie
Sep 4, 2006
54
also, do I just buy a new MAF and fit it, or do I need to get the faults cleared or something to get the lights to go away?
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
If it is the MAF, you can just buy one and plug it in. No need to clear codes, lights will go off soon after fitting.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
they get noiser over the first couple hundred miles
if you did any of your install with MAF disconnected and ign on then yea you will have popped a code..
MAF is fragile so any knock can upset/damage them
good luck
