jacking the engine up?
flooky
Hi all, How should I go about jacking my engine up? I need to replace the front engine mount from what I can gather.
Cheers.
flooky
ive found that the bolt has come out holding the engine to the engine mount? any ideas where i can get another of these bolts? will the mount be damaged at all you think?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's possible it'll be damaged, but not likely
just jack the engine gently with a trolley jack under the gearbox (with some wood to protect it)
flooky
cheers, any idea what size the bolt will be? or where i can get another from?
WeeJase
pert
Jun 2, 2001
8,595
you don't need to lift it as such,just take the slack up /support it,the front mount is a doddle.
flooky
i cant find a part number for this bolt i need, does anyone have it? ive searched on here with no luck...
