Jabbasport Heat Shield - Pictures
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Anyone got any pictures of the jabbasport induction kit fitted to their car, and pictures of how it was supplied?? I know you get the heat shield, filter, breather filter but do you get anything else?
Really interested in pictures of where the JR cone mounts (presume onto MAF tube) and if any flexible tubing was supplied with the kit? Becaus i'll be running an S3 TIP i'll need some sort of flexible piping to make it fit right.
May 2, 2006
2,758
Their was no flexing tubing supplied mate
as you say its just the sheild, filter and breather
will post picks up (photobucket is down at the min)
May 2, 2006
2,758
photobucket is back up now
will get some more detailed ones at dinner mate
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
all that heat from the battery must be a killer!
I dont bother with heatshields, when youre moving forward the warmer air is being drawn away from the engine bay anyway so by fitting a block to other fresh air coming through the grill, I cant see how it is improving the situation, the fmic will be cooling the air as much as possible anyway.
May 2, 2006
2,758
craig, i know what you mean, inbetween the tip and the maf? thats off the original oe airbox, if you havnt got one, get a 70mm 45degree bend of silicone from forge (if your going amo4 it will need to be 80mm)
filter just goes onto maftube yes, with a little lip on the sheild if i remember right
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Ahh I'll check my standard tip for it then, I was actually thinking of leaving the MAF in the OEM position and using some silicone pipe and a join to fit the filter to to stop any vibrations trying to kill the MAF.
May 2, 2006
2,758
its an idea mate, im going to replace my bit with a silicone jobbie, just not got round to ordering it yet
