ive got fault codes...
meltonlad
391
huntingdon
ive just ran VAGCOM and got the following codes:
16497 and 16486
i know one of them is maf related but could the two to connected ??
car runs fine but mpg is a bit lower but i put it down to short trips round town but i could be wrong. any advice or help would be great peeps :)
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
There you go mate ;)
16497/P0113 - Intake Air Temperature (IAT) Sensor 1 Circuit (G42): High Input
Possible Symptoms
unknown
Possible Causes
Open circuit in harness
Improper harness connection
Sensor signal short to power
G42 faulty
Control Module faulty
Possible Solutions
Check wiring and connections
Check / Replace G42
Check / Replace Controle Module
16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
Possible Symptoms
Probably no serious malfunctions
Loss of power
Possible Causes
Wiring and/or connections (short circuit?)
Mass Air Flow (MAF) (G70) defective
Possible Solutions
Check / Replace Mass Air Flow (MAF) (G70)
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Intake air temp sensor. Put a post up in Sere Motors section, they'll get you a good price. Not sure on the location though
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
See the arrow?
meltonlad
391
huntingdon
thanks LEE but mine has got the AGN engine so different to the pic. ive had another look round but still cant find nowt. could this prob be the cause of lower mpg ?? also is it still ok to drive round in it ??
meltonlad
391
huntingdon
all sorted now. i disconected the maf sensor and removed the airbox when i was looking for a water leak. i then started the car and left it running for a min to look for leak when running. ive cleared all codes ran around for a few days and no failts have come back.... so must have been when i started car !!
