Now before people start shouting "search bar" at me, believe you me, l've spent many hours reading every thread l can find stretching back many months.......but l'm still no wiser on the situation
So the story goes.............at the end of last week l took all my calipers off to refurbish them with the intentions of changing all the discs and pads at the same time along with a load of other much need maintenance. Now after one problem or another, over a couple of days, l ended up having all the fluid drain out of the system leaving me with a system full of air which l know is NOT good!
l've read through countless posts about bleeding the system and other related issues and although drained systems come up in conversation a few times, no advice is given as to how you should go about refilling the system (people just simply say "DO NOT let it happen", but obviouslly on this occassion, it was totally out of my control)
Do l simply refill the reservoir, attach my Esibleed and crack on in the usual manor or is there something else l should be doing because of the current predicament l've found myself in?
Any help or light anyone can shed on the situation will be greatfully received!
