isit just me that can't see naff all due to mist?
nutty_merka
72
Door seals all re-done checked the cabin filter this was fine, this seemed to be a success footwells have started to dry out how ever I have excessive mist on all windows front especially, not that I have plans to use it at all but air cons not working, when I press the button it doesn't stay on, I no the mist is usually assosiated with dampness but this is beyond a joke at first the mist used to go away slowly with the climate control on now it does eff all. Anyone?
nutty_merka
72
if your in the uk and its cold air con dont work till 5 degrees also it will take weeks to dry out after you stop leaks
Ahh I see, that explains a lot, I think I'm going to go to the vallet place to get them to wet vac the carpets see if this helps with the moisture, thanks for your responce though matty85
Bickerton
401
They use em to dry out flooded houses and you can pop em in a room with wet clothes and speeds up the drying alot! Ask family etc, its the sorta thing someone will probably have.
nutty_merka
72
Its obviously not going to solve my problem in the long run but I'm impressed by the cheapo demister sponge I got from asda works magic in comparison to wiping it with a cloth or other pieces of material I've previously tried. I'm gonna try the wet vac and dehumidifing method first don't really want to go down the long route off taking the carpet up.
dazjstuart
660
8
Aberdeen
As others have said, get a wet hoover on it, good opportunity to give it a thorough clean. Either hire a big electric dehumidifier which will get the job done quickly, or buy a couple of the little ones that you take out and recharge when they get full, they will probably take a wee while to dry the car out properly but just keep them in there.
nutty_merka
72
+ centre console bit, I suppose I've slightly exaggerated it abit but there again everythings long in this weather outside :lol:
Bickerton
401
If you feel brutal you could lift up the carpet and cut out the section of underlay and dry it in the house?
nutty_merka
72
As others have said, get a wet hoover on it, good opportunity to give it a thorough clean. Either hire a big electric de humidifier which will get the job done quickly, or buy a couple of the little ones that you take out and recharge when they get full, they will probably take a wee while to dry the car out properly but just keep them in there.
Yer I'm on to it mate, any good recomended dehumidifiers. Fleebay links welcome, it'll help me and a lot of other people out?
