Is there supposed to be a switched 12v supply in the ISO connectors?
Apr 8, 2025
Am I going crazy? I’m replacing the HU in my son's car with something more contemporary than factory (a JVC KW-M560BT).
I’ve had a poke around the ISO connectors in the car with my multi meter, and there doesn’t seem to be a switched 12v supply there.
Is this to be expected and do I need to run a line from the fuse box or something?
Thank sin Advance!
Feb 7, 2025
Thank sin Advance!
Hello, yes there is one. If you have the standard radio, it will be the wire marked S-Kontakt or S-Line or S-Kon. In both my mk4 Ibiza Cupra and my Polo 9n3 these wires are black with a red stripe. You will get 12v when you turn the key in the ignition and it will turn off when you pull your keys out of the ignition.
