Is my water temp to high?
dogmark
52 reg seat leon 1.4 engine
my temp reader seems to settle over the 90 - bewteen 1/2 and 3/4
I have read the manual and it says it is the normal level but i have never had a car that goes over 90 deg.
it is a new car ( for me ) only had it 4 weeks , am i worrying about nothing
thanks
D3DNA
391
Cov
Its normal to be higher than 90 in some conditions but it may be worth having it looked at. If it holds at the same temp when run for over 5 minutes it may be something minor, if it drastically changes temp after a short period from cold then something is up.
CupraJay
20v T - Its where its at!
Jan 17, 2006
333
South Wales
as far as i was aware..the temp should sit on 90c no matter what.
Iv give me car a good hammering, quite frequently, and iv never seen it rise over 90c. Mind u, i dont spend much time looking at it.
dj_hektik
LEON 20VT FR
Temp should not go higher than 1/2. I've had my car for 20,000 km's now in Saudi arabia and the water temp gauge has never gone above 1/2.
P.S. heat here is 45-50 degrees in the daytime. + my car is a turbo, not a 1.4
i'd have a mechanis look at it - might be the start of something (i dont mean to worry you but it's better to be careful)
CupraJay
Jan 17, 2006
333
South Wales
The water pump impeller is prone to breaking..Maybes its started to break up, hence temp rising..
If its the case, replce the impeller with a brass metal impeller. Westec stock them. ;)
dogmark
well i went out tonight and gave the car a good run round the m25 and back up the m4 no problems and it sat at 90 all the way ( took about 2 miles to get upto 90)
i will keep my eye on it
mmfb
149
Berkshire
90. Except when my water pump broke. This happened gradully with the temp getting slightly higher over a period of time. Initially it looked like it was only a fuse - so this was changed, and it was better for about 1 week, then started climbing again. Eventually it got to the warning light and the water pump got changed - problem solved.
mmfb
149
Berkshire
Oh. Just t o add...I could drive a few miles, and it would maintain the temp for most of the time, but gradually increase the longer I drove. After about 4 miles it was above the 90.
dogmark
well i have sussed out when it happens now
if i drive get the car upto 90 then turn the engine off , then start the engine again it creeps above the 90 mark then when it goes above 90 the fan cuts in and it maintains this level , when the engine cools and i start up again it hits 90 and stays there:wtf:
