Is my coolant temp sender faulty?
GazM
96
Leicester
I've had suspicions about it because the car idles lumpy sometimes, especially when cold, and other people here seem to have those symptoms with a faulty cts.
What's really made me think is I had vag-com plugged in this morning and at the end of my 1/2 hour trip to work the coolant temp reading from it was only in the mid to high 70's, when the temp guage on the instrument panel was reading 90.
Is this normal?
mikecupra
If there was a fault with the coolant sensor then vag-com should have recognised a fault code that was relevant to it i would have thought?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
be aware that lots of leons can suffer from lumpy surgy cold starts.. not saying yours is like this but id keep it at the back of your mind before shelling out on sensors etc. unless of course they report as faulty
GazM
96
Leicester
Ok, thanks both. I just thought the reading after 30 mins driving was odd.
At least it doesn't have far to go to get to the back of my mind :lol:
honeyman
Pirates
Oct 20, 2004
614
Northampton
I had the coolant sensor play up on mine with the same problems as yours and it didn't throw up anything on Vag-com, I've since changed to the green sensor.
honeyman
Pirates
Oct 20, 2004
614
Northampton
I'd say it was 80-90% better, as you know owning a turbo'd car it can change daily, but on the whole yes it was better, also no more annoying beeps first thing in the morning.
driveforward
Is at the Nürburgring
Nov 5, 2002
3,245
www.driveforward.com
The coolant temp sensor on our LC 20VT was causing a 'signal level too high' fault for quite a while. I cleared the code a number of times, but it kept returning and eventually caused a warning light to come on. Sensor has now been replaced, all is well again.
Ian
honeyman
Pirates
Oct 20, 2004
614
Northampton
Well if you don't change the sensor and wait till the cold mornings start then you'll get the three beeps and temp light flashing, but it tends not to do it in the summer months.
