Is it possible to turn off the turbo via a controller?
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
Just crossed my mind yesterday driving back from hull,
i managed a resectable 38-39 mpg sat at a good 68-70,
the question i have is there anyway you can plumb say something like a boost controller to actually stop the actuator opening so its practically running as an N/A Engine,
im doing a lot more travelling due too a new missus, and i cant bring myself to buy a diesel, i want to keep the 20vt, and to see if i can increase the mpg even more
cheers people!
karlw
AKA Shifty - Modded LCR
Jan 29, 2010
218
Ipswich, Suffolk
no not really even if you had something good like an avcr switching it off will still let it run to standard pressure usually set by the actuator
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You got a boost gauge fitted?
If not get one and drive by it should increase the mpg loads tbh, bloody boring though (yes i have tried it)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
cheers people!
stopping actuator opening will give you uncontrolled boost, so thats not what to do
electrically disconnect n75 and you will run maximum 5-7psi boost which is very little.
OR
learn throttle control :p ;)
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
put an electronic solenoid in parallel with the n75; when you don't want boost turn it on so it lets boost straight to the actuator - this will give you around 6psi max boost; then when you want boost, turn it off, boost goes back to n75 control.
The 6mm variety of this is what I use (it is not listed atm):
http://cgi.ebay.co.uk/Solenoid-Valv...arParts_SM?hash=item4cee34451e#ht_2062wt_1165
I use this setup to cut my boost when I run out of water/meth to avoid doing engine damage.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Turbocharger improves engine efficiency, by increasing the compression ratio (to summarise drastically). Driving "off boost" is not the answer, driving economically is.
Accelerate just enough to be secure (get away from full stops smartly, overtake safely) don't cane it every time, that will drink fuel down. On long runs, choose a speed and stick to it. 70 is *much* better than 80 for economy, and will get you there in practically the same time (traffic dictates your point-to-point speed much more than you'd like to think). Above 80 (should you choose to go there: don't tell us about it) will really cane your economy. Look further ahead, anticipate the traffic speeds and gaps and use engine braking rather than the footbrake.
At the end of the day, you're using a sports car as a daily driver. Don't expect too much, but you need more than one style of driving.
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
OR
Just tried that with the N75, I actually really liked it for a change! nice and smooth, dont have to be so careful what you're doing with your right foot! It would be nice to do along the lines of what you were saying Danny about having a switch installed to essentially turn the boost up and down... do you need one of those solenoids or can you just literally wire a switch into one of the cables leading to the N75?
I Guess what I'm also asking here is, will you get the dreaded EML leaving the N75 unplugged?
Also, economy wise, will it reduce the MPG as the ECU will have one less control parameter for the engine? I noticed that on the trip computer at least, the MPG is better - floored in third I'm seeing a lowest value of 7 as opposed to 5 now....
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
dont get me wrong, im not complaining, at 39mpg from a 1.8t i think thats respectable, i was just seeing if it was possible to up it by another 5-10mpg, everyone knows the use of the turbo just guzzles fuel, and no the leon isnt a daily driver, i have the trusty transit for that,
a 90 mile trip to hull and back is costing about 20 quid a chuck, even to bring that down by a couple of quid, it'd make all the difference,
The cupras staying, it wouldnt look too good picking up the OH in a pikey chariot, :happy:
The heavy right foot situ, i cant really help, its not the speed that gets me smiling, its the acceleration, thats where i struggle!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Well, as usual, what everybody knows isn't completely right: Use the turbo in a different way and you can get good economy too. Although I think that 39mpg is going to be hard to beat without letting a lot of people overtake you :(
Some tuners do switchable maps, I think, selectable from the dashboard. You could always get an "economy" map, and switch it out when you feel like a bit of fun :)
Presently I'm commuting 90 miles each way, round the bottom half of the M25, four days a week. Hire car and fuel on expenses, and it's only for six months, or I'd not stomach it. Getting 42-45mpg out of a Peugeot 207SW with a 95bhp 1.4 engine, faintly ridiculous little sewing machine. It's OK, but you've got to keep the revs up, or it has no go at all - not very "driveable"... That's what I like about my boring diesel, decent power from low down, easy to drive in the town.
Ah, yes, it does bring a smile to the face, doesn't it. I remember how I felt after trying a Mk.1 Golf GTI for the first time - silly grins all round :D. Bought it, and followed it with a Mk.2. Both stolen from me :cry:
Dyscontinued
1,142
Leeds
I don't understand why a turbo would make the fuel consumption more, from what I understand all a turbo does is use exhaust (so waste) gas to turn a turbine which compresses air and to increase the o2 content hence making more efficient combustion.
no?
