ipod in mk3
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
beattie17 said:
is it possible to wire ipod up to standard headunit?if so how?
Search with Google!
http://www.ipodcarkitdirect.co.uk/iPod_Car_Kits/For_Factory_Fitted_Radios/Se at_iPod_Car_Kits
Search the site, it's been done loads of times with the factory radio or other.
Mikey.B
53
Kings Lynn
I have a dension lead you can listen to the first 5 playlists or you can control it all through the ipod, i use it like this as i cant be arsed with playlists..
If you have a Video ipod you can watch videos as well, not recommended at speeds over 100mph....:think:
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
beattie17 said:
Click the link in the post, Choose SEAT, Choose DENSION, Select '99 and on, then make the choice between a proper Cradle for it, or just a cable.
If, when you're on that page, if you look down the page you can see a photo of each choice.
My advice - if it's not coming together on the web, just call them and tell them what you want.
Rich
uniseat
technical
Jul 13, 2005
76
Holland
www.mijnalbum.nl
If ya can solder then its possible, to solder the wires directly to the radio unit. This is only possible if ya have a cd changer. Solder them to C3(iso connection)
# Pin 18 - CDC audio frequency ground
# Pin 19 - CDC audio frequency left
# Pin 20 - CDC audio frequency right - CD changer.
Solder a 3 mm jack for ya ipod.
Record a blanco track for 80 min.
Burn a the blanco track on a cd. Put it in the cd changer, play the cd. Start ya ipod.
Im using it also in my car for a year now, and works great.
Gr Bas
Mikey.B
53
Kings Lynn
Just a suggestion, but when i got my dension i>link cable i did not get the cradle, i just got the lead....Cos i dont know about you but i have a case on my ipod and it would not fit in the cradle without taking the case of each time....
You can still buy a separate holder and use a brodit screw-less dash mounting...
Like this http://www.handnav.co.uk/product_details.php?id=199
Look here for all what you need http://www.brodit.com/
In fact tonight i got out of my car and dropped my ipod on the gravel and stood on it would have been wrecked without the case me thinks.....
Mikey.B
53
Kings Lynn
I thought so to shame i have not brought one yet :doh:
The little storage space near the gear stick is were mine is professionally installed.....:D
The Brodit clips are good though my mate had one.........
