Intermittent starting probs
gmjgreg7
Hi All,
I've been having a problem with the car over the last few weeks and I was wondering if anyone has experienced anything similar and could suggest what might be causing it.
The car is a 2001 1.8T cupra.
On turning the key in the ignition the starter motor runs but the engine doesn't fire up. Initially I thought it was a problem with the battery but I have tested the voltage across it both without (approx. 12V) and with (approx. 14V) the engine running - so that seems fine. If I hold the key in place so that the starter motor keeps turning it does fire up after about 15 seconds, but the last time I did this there was a very strong smell of unburnt petrol.
If the car doesn't start up on the first go then a second turn of the key gets it going. The problem is very intermittent, doesn't seem to be anything in common about when it happens - fuel level, hot or cold engine, wet or dry weather, hot or cold outside temperature.
A few of things that I'd thought might be causing the problem were; the immobiliser, the coil pack and whatever holds the pressure in the injectors (used to be the accumulator on my old 16v).
Anyway, If anyone can offer any advice it'd be much appreciated.
Cheers,
-Greg
Rick-24
443
i had this....the car would turn ova but wouldnt fire up, and it only happened after some serious rainfall, i checked it on vag com and had no faults logged, and i didnt really sort the problem out i just left it and came back and it fired:confused: ..... i am putting it down to water, something getting damp<ecu maybe? other people had similar problems
Tony 156
468
Thatcham
I think all cars have this problem to a certain degree, ive had it on a few of mine, no rhyme or reason just som days there not interested in starting. i wouldnt wory about it too much.
why do you think cars have girs names. they are just as tempremental!
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
mines doin the same now some time wont start somes starts runs then cuts out. you need a 6no 905865 i got 1 2day fitting it in a bit!
gmjgreg7
Hi Turboboy,
How did you get along fitting the part you mentioned, has it made much difference?
Cheers,
-Greg
gmjgreg7
Just a quick update to say that I received a message from TurboBoy to say that fitting the replacement part (6no 905865) fixed the problem for him... not sure what the part is or how difficult it is to fit/get to/change but I'm gonna see if I can get hold of one.
-Greg
BillyWhizz
BillyLeonCupra08
Nov 21, 2005
62
Newbury
Hi All,
I have started to get the same problem with my Ibiza that you guys are discussing on this thread, can you all say for sure that fitting a 6N0 905 865 (Ignition switch) has fixed your problem.
As previously stated this problem is very intermittent, I just want to make sure that you haven’t seen the likes of this problem since.
Also how much did the part cost???
