Foz550
Hi, I posted this in the TDI section but have had no repies so I hope people dont mind me putting it in here as well!!!
Am having big issues with my leon FR TDI (55 plate, 52k), it keeps intermittently losing power (feels like the turbo goes) which if I turn the engine on and off again stops the problem and all is well again.
VAG said it was the fuel pump relay, so had that changed & still same issue & I have now had the fuel pump changed as well and I still seem to be losing power intermittently.
When I had the fuel pump changed my mechanic did a lot of VAG tests etc & it came up with the following code/problem:
17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
P1549 - 35-10 - - - Intermittent
Anyone got any ideas on what my problem could be? Is it likely to be this N75 valve?
Ive also had the following code come up a few times, do you guys think I need to change the fan system? my mechanic says this wont fix itself and will slowly get worse & pack up, apparently quite common?
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Thanks in advance!?
Dave
Thanks in advance!?
Dave
