Deleted member 20482
hi all.
i changed all my bulbs to the "white/blue" lights and all was fine, but recently my front fogs have started to not work when switched on,so i get out of the car and give them a little kick then they work.... question is, is it the bulbs or the connections or the switch in the car?
i have taken apart b4 and can't see anything wrong with the bulb or how its connected...so at a loss at mo...
anybody got any ideas or had a similar problem?
The switch looks the same as my Audi, I.E pull the headlight switch for fogs?
More than likely it will be the switch, its a commonish problem across the VAG range...
my h7s were doing this, but i think because my LED festoons had gone on my rear bumper, they were causing a short somewhere..so iv changed the festoons, removed the h7 and put it back and now there working fine
I had a problem with my Fogs coming on with my main beam - turned out the switch needed removing from the dash and pushing back togethr as it had a loose connection at the back - might well be your problem too.
well when i get my car back from the body shop again(didn't do a good job on respray)
i shall look at the switch... if not then still stumped..
cnat put orig bulbs back as not got them anymore...doh!!!!!
