Interior upgrades
Dec 21, 2019
Looking to upgrade the sound system. Is there any people have in mind or anything that has been done and what to look out for? Is it possible? Iam new to owning a Leon and don't know much about them any help would be much appreciated thanks. Josh
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
What’s the reason to upgrade?
if it’s “rattles” you may benefit from sound deadening the door cards as the speakers cause them to rattle a lot on some. (Bad deadening from factory).
also worth playing with the EQ before jumping in and spending ££££ on a new speakers system.
ZK_FR150
220
32
As above the main question is why, due to the headunit being integrated with the car settings it's tricky to upgrade without spending quite a bit of money, I think only Alpine makes a headunit that can be replaced which keeps all the current functionality of the car but it's about £800.
You can do a little or a lot it just depends on your budget.
Even if you don't have rattles sound deadening the doors first will make a big difference to the current sound quality.
Then if you want better quality look to replacing the speakers with better ones to run off the head unit, although to get the best out of them will mean you will need to add an amp or 2 and you will then also be able to add some subs, however you should hear some improvements just by changing out the stock speakers.
To do this you will need amps that have speaker level inputs or invest in a line out converter as there aren't any pre-outs on the headunit to connect to the amps, some are cheap and others are expensive.
Don't forget all this will need wiring in via the battery so will need a lot of the trim removing as well and splicing into existing wiring.
After this you're looking at custom builds and system tuning and higher end components which is ££££.
If you just want to do a slight upgrade I'd recommended just sound deadening all the door cards first and see how it sounds and then maybe look to change the stock speakers to some better ones, this should all be doable for around £2/300 odd, after that it does start getting expensive.
Ninja10R
194
30
Athens, Greece
www.trackbike.gr
Something like this will give you RCA outputs, plus it will let you keep all the factory settings - drive modes etc on the head unit without having to pay much. The previous owner of my TDi 184 had one installed and i'm very pleased with it (time to upgrade the speakers, get an amp and a self powered sub for the boot though).
https://www.ebay.com/itm/Android-9-...812651?hash=item216664f32b:g:bysAAOSwAHtc3krd
