Well i managed to fix the electric window switches now so my passengers can now control their own window. But i have two other problems.
1. When i open the front passenger side door, the puddle light (courtesy light in the door) doesn't turn on. I know it's not the bulb or fuse causing this problem. All the other doors work just fine. The other problem on this door is that if i press the lock button inside the car, the passenger side door locks and unlocks straight away. It also does this if i press the lock button twice on my keyfob.
2. The second problem is that my boot light doesn't work. I have checked the fuses and the bulb and they are fine. If i touch the boot light on some bare metal, the light works until i take it off. Is there a switch i can clean and where is it?
Is there a switch or an earth point i can clean to fix my above problems, if so, where are they?
Thanks very much for your help in advance
